Steam Deck Fan Replacement
Выберете то, что вам нужно
  1. Steam Deck Fan Replacement, Prepare your device: шаг 1, изображение 1 из 3 Steam Deck Fan Replacement, Prepare your device: шаг 1, изображение 2 из 3 Steam Deck Fan Replacement, Prepare your device: шаг 1, изображение 3 из 3
    • Turn on your Steam Deck and allow the battery to discharge below 25% before starting your repairs, as a charged lithium-ion polymer battery can be dangerous if accidentally punctured.
    • As an extra precaution, Valve recommends putting your Steam Deck into battery storage mode within the BIOS before starting any internal repairs. Read how to do that here.
    • Power down your Steam Deck and unplug any cables.
    • If you have a microSD card installed, make sure to remove it before opening the Steam Deck. If you attempt to remove the back cover with it still installed, it could snap right in half.
    • During your repair, it can be helpful at times to lay the Steam Deck face-down into its case to protect the thumbsticks and prevent wobble.
    • Use a Phillips driver to remove the eight screws securing the back cover:
    • Four coarse thread 9.5 mm-long screws
    • Four fine thread 5.8 mm-long screws
    • Despite the standards, Phillips screwdrivers can vary in size and shape—two drivers labeled as the same size may fit differently in the same screw. Use the size that fits the snuggest into the screw head.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your Steam Deck.
  2. Steam Deck Fan Replacement, Unclip the back cover: шаг 3, изображение 1 из 2 Steam Deck Fan Replacement, Unclip the back cover: шаг 3, изображение 2 из 2
    • Insert an opening pick into the thin gap between the back cover and the front shell, along the edge of the right grip.
    • If you're having trouble inserting your pick at the grip seam, try starting at either the top or bottom long edges first, then slide the pick towards the grip.
    • Pry up on the back cover to release it from the locking clips.
  3. Steam Deck Fan Replacement, Remove the back cover: шаг 4, изображение 1 из 3 Steam Deck Fan Replacement, Remove the back cover: шаг 4, изображение 2 из 3 Steam Deck Fan Replacement, Remove the back cover: шаг 4, изображение 3 из 3
    • Once the clips are disconnected from one edge, the rest disconnect easily.
    • Grip the back cover at the opening you just created and pull it up and away from the device to unclip the long edges.
    • Remove the back cover.
  4. Steam Deck Fan Replacement, Uncover the hidden shield screw: шаг 5, изображение 1 из 2 Steam Deck Fan Replacement, Uncover the hidden shield screw: шаг 5, изображение 2 из 2
    • If you have a refreshed Steam Deck version with the black motherboard cover, skip this step.
    • Use a pair of tweezers to remove the piece of foil tape covering the hidden screw on the board shield.
    • If possible, try not to rip or tear this tape so it can be reused. If necessary, you can fashion a replacement by cutting a piece of aluminum foil tape to fit.
  5. Steam Deck Fan Replacement, Remove the shield screws: шаг 6, изображение 1 из 2 Steam Deck Fan Replacement, Remove the shield screws: шаг 6, изображение 2 из 2
    • Use a Phillips driver to remove the three screws securing the board shield:
    • One 3.4 mm screw
    • Two 3.7 mm screws
    • Only the two 3.7 mm screws along the left edge are present in refreshed Steam Decks.
  6. Steam Deck Fan Replacement, Remove the shield: шаг 7, изображение 1 из 3 Steam Deck Fan Replacement, Remove the shield: шаг 7, изображение 2 из 3 Steam Deck Fan Replacement, Remove the shield: шаг 7, изображение 3 из 3
    • Remove the board shield.
    • Depending on the age of your Steam Deck, this shield may stick to the thermal pads underneath.
    • During reassembly, ensure that the fan cable lays on the side of the board shield and isn't pinched underneath.
  7. Steam Deck Fan Replacement, Disconnect the battery: шаг 8, изображение 1 из 3 Steam Deck Fan Replacement, Disconnect the battery: шаг 8, изображение 2 из 3 Steam Deck Fan Replacement, Disconnect the battery: шаг 8, изображение 3 из 3
    • Grip the battery cable by its pull tab and pull it directly away from the motherboard to disconnect it.
    • Alternatively, use the flat end of a spudger or a clean fingernail to gently push the connector out of its socket, then disconnect it completely by hand.
  8. Steam Deck Fan Replacement, Remove the heatsink sticker: шаг 9, изображение 1 из 3 Steam Deck Fan Replacement, Remove the heatsink sticker: шаг 9, изображение 2 из 3 Steam Deck Fan Replacement, Remove the heatsink sticker: шаг 9, изображение 3 из 3
    • Use a pair of tweezers to remove the sticker from the top edge of the fan.
    • If possible, try not to rip or tear this sticker so it can be reused. Use a little bit of heat if necessary to soften the adhesive.
    • If the sticker feels like it might tear, use tweezers to peel up one edge just until you can grip it with your fingers, then remove the rest by hand.
  9. Steam Deck Fan Replacement, Disconnect the fan: шаг 10, изображение 1 из 3 Steam Deck Fan Replacement, Disconnect the fan: шаг 10, изображение 2 из 3 Steam Deck Fan Replacement, Disconnect the fan: шаг 10, изображение 3 из 3
    • Use a pair of tweezers to grip the edges of the fan connector and pull up to disconnect it from the motherboard.
    • Pull the fan cable by its connector, not the wires themselves.
    • During reassembly, be gentle while plugging in the fan connector.
    • If the connector is misaligned, the use of too much force can damage the fragile internal pins.
  10. Steam Deck Fan Replacement, Remove the fan screws: шаг 11, изображение 1 из 1
    • Use a Phillips driver to remove the two 3.7 mm screws securing the fan.
    • No, your eyes don't deceive you! The other two fan screws were removed earlier in the disassembly: they double as two back cover screws.
  11. Steam Deck Fan Replacement, Remove the fan: шаг 12, изображение 1 из 1
    • Remove the fan.
    • When installing a replacement fan, peel off the plastic liner on the cable adhesive and adhere it to the fan body in the same location as the cable on the old fan, so it'll lay on the side of the board shield and not get pinched underneath.
Заключение
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Steam Deck answers community for help.
68 участников успешно повторили данное руководство.
Carsten Frauenheim
Участник с: 03/10/20
104 487 Репутация
Автор 338 руководств
Команда
iFixit Участник iFixit
Community
142 членов
Автор 16 238 руководств
22 Комментариев
Hi ifixit Team, as the cooler seems to be a non factory one: how does it compare noise wise to the standard Steam Deck cooler, which is unbearably loud?
Peter Black - Ответить
I addition to Peter's comment, in would be helpful to know the manufacturer and model. It would seem that there are at least two, perhaps more models being used; one brand in particular being prone to the high-pitched "whining" issue.
Cameron - Ответить
To those asking, you want a huaying fan as opposed to a delta fan. The delta is terribly bad with its acoustics.
Christopher Stanton - Ответить
is this the delta or huaying?
Mono Chrome - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 55
За последние 7 дней: 509
За последние 30 дней: 2,677
За всё время: 87,442
