Steam Deck Motherboard Replacement
Выберете то, что вам нужно
  1. Steam Deck Motherboard Replacement, Prepare your device: шаг 1, изображение 1 из 3 Steam Deck Motherboard Replacement, Prepare your device: шаг 1, изображение 2 из 3 Steam Deck Motherboard Replacement, Prepare your device: шаг 1, изображение 3 из 3
    • Turn on your Steam Deck and allow the battery to discharge below 25% before starting your repairs, as a charged lithium-ion polymer battery can be dangerous if accidentally punctured.
    • As an extra precaution, Valve recommends putting your Steam Deck into battery storage mode within the BIOS before starting any internal repairs. Read how to do that here.
    • Power down your Steam Deck and unplug any cables.
    • If you have a microSD card installed, make sure to remove it before opening the Steam Deck. If you attempt to remove the back cover with it still installed, it could snap right in half.
    • During your repair, it can be helpful at times to lay the Steam Deck face-down into its case to protect the thumbsticks and prevent wobble.
    • Use a Phillips driver to remove the eight screws securing the back cover:
    • Four 9.5 mm screws
    • Four 5.8 mm screws
    • Despite the standards, Phillips screwdrivers can vary in size and shape—two drivers labeled as the same size may fit differently in the same screw. Use the size that fits the snuggest into the screw head.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your Steam Deck.
  2. Steam Deck Motherboard Replacement, Unclip the back cover: шаг 3, изображение 1 из 2 Steam Deck Motherboard Replacement, Unclip the back cover: шаг 3, изображение 2 из 2
    • Insert an opening pick into the thin gap between the back cover and the front shell, along the edge of the right grip.
    • If you're having trouble inserting your pick at the grip seam, try starting at either the top or bottom long edges first, then slide the pick towards the grip.
    • Pry up on the back cover to release it from the locking clips.
  3. Steam Deck Motherboard Replacement, Remove the back cover: шаг 4, изображение 1 из 3 Steam Deck Motherboard Replacement, Remove the back cover: шаг 4, изображение 2 из 3 Steam Deck Motherboard Replacement, Remove the back cover: шаг 4, изображение 3 из 3
    • Once the clips are disconnected from one edge, the rest disconnect easily.
    • Grip the back cover at the opening you just created and pull it up and away from the device to unclip the long edges.
    • Remove the back cover.
  4. Steam Deck Motherboard Replacement, Uncover the hidden shield screw: шаг 5, изображение 1 из 2 Steam Deck Motherboard Replacement, Uncover the hidden shield screw: шаг 5, изображение 2 из 2
    • Use a pair of tweezers to remove the piece of foil tape covering the hidden screw on the board shield.
    • If possible, try not to rip or tear this tape so it can be reused. If necessary, you can fashion a replacement by cutting a piece of aluminum foil tape to fit.
  5. Steam Deck Motherboard Replacement, Remove the shield screws: шаг 6, изображение 1 из 1
    • Use a Phillips driver to remove the three screws securing the board shield:
    • One 3.4 mm screw
    • Two 3.7 mm screws
  6. Steam Deck Motherboard Replacement, Remove the shield: шаг 7, изображение 1 из 2 Steam Deck Motherboard Replacement, Remove the shield: шаг 7, изображение 2 из 2
  7. Steam Deck Motherboard Replacement, Disconnect the battery: шаг 8, изображение 1 из 3 Steam Deck Motherboard Replacement, Disconnect the battery: шаг 8, изображение 2 из 3 Steam Deck Motherboard Replacement, Disconnect the battery: шаг 8, изображение 3 из 3
    • Grip the battery cable by its pull tab and pull it directly away from the motherboard to disconnect it.
    • Alternatively, use the flat end of a spudger or a clean fingernail to gently push the connector out of its socket, then disconnect it completely by hand.
  8. Steam Deck Motherboard Replacement, Remove the SSD screw: шаг 9, изображение 1 из 1
    • Use a Phillips driver to remove the 3.4 mm screw securing the SSD.
  9. Steam Deck Motherboard Replacement, Remove the SSD: шаг 10, изображение 1 из 2 Steam Deck Motherboard Replacement, Remove the SSD: шаг 10, изображение 2 из 2
    • With the SSD screw removed, the SSD will pop up at a shallow angle.
    • Grip the end of the SSD and pull it away from its M.2 board connector to remove it.
    • During reassembly, insert the SSD at a shallow angle into its board connector, and secure it back into its horizontal position with the SSD screw.
  10. Steam Deck Motherboard Replacement, Remove the heatsink sticker: шаг 11, изображение 1 из 3 Steam Deck Motherboard Replacement, Remove the heatsink sticker: шаг 11, изображение 2 из 3 Steam Deck Motherboard Replacement, Remove the heatsink sticker: шаг 11, изображение 3 из 3
    • Use a pair of tweezers to remove the sticker from the top edge of the fan.
    • If possible, try not to rip or tear this sticker so it can be reused. Use a little bit of heat if necessary to soften the adhesive.
    • If the sticker feels like it might tear, use tweezers to peel up one edge just until you can grip it with your fingers, then remove the rest by hand.
  11. Steam Deck Motherboard Replacement, Remove the heatsink screws: шаг 12, изображение 1 из 1
    • Use a Phillips driver to loosen and remove the two screws securing the heatsink to the motherboard:
    • One captive 3.5 mm screw
    • One 3.4 mm screw
    • No, your eyes don't deceive you! The third heatsink screw was removed earlier in the disassembly: it doubles as the hidden board shield screw.
  12. Steam Deck Motherboard Replacement, Remove the heatsink: шаг 13, изображение 1 из 3 Steam Deck Motherboard Replacement, Remove the heatsink: шаг 13, изображение 2 из 3 Steam Deck Motherboard Replacement, Remove the heatsink: шаг 13, изображение 3 из 3
    • Lift and remove the heatsink.
    • Before reinstalling the heatsink, follow this guide to clean the heatsink and APU and reapply thermal paste.
  13. Steam Deck Motherboard Replacement, Disconnect the fan: шаг 14, изображение 1 из 2 Steam Deck Motherboard Replacement, Disconnect the fan: шаг 14, изображение 2 из 2
    • Use a pair of tweezers to grip the edges of the fan connector and pull up to disconnect it from the motherboard.
    • Pull the fan cable by its connector, not the wires themselves.
  14. Steam Deck Motherboard Replacement, Remove the Wi-Fi shield tape: шаг 15, изображение 1 из 3 Steam Deck Motherboard Replacement, Remove the Wi-Fi shield tape: шаг 15, изображение 2 из 3 Steam Deck Motherboard Replacement, Remove the Wi-Fi shield tape: шаг 15, изображение 3 из 3
    • Use a pair of tweezers to peel up and remove the Wi-Fi shield tape.
  15. Steam Deck Motherboard Replacement, Disconnect the speakers: шаг 16, изображение 1 из 2 Steam Deck Motherboard Replacement, Disconnect the speakers: шаг 16, изображение 2 из 2
    • Use a pair of tweezers to grip the edges of the speaker connector and pull up to disconnect it from the motherboard.
    • Pull the speaker cable by its connector, not the wires themselves.
  16. Steam Deck Motherboard Replacement, Disconnect the Wi-Fi: шаг 17, изображение 1 из 3 Steam Deck Motherboard Replacement, Disconnect the Wi-Fi: шаг 17, изображение 2 из 3 Steam Deck Motherboard Replacement, Disconnect the Wi-Fi: шаг 17, изображение 3 из 3
    • Use a pair of tweezers to grip the antenna connector close to its base.
    • Pull straight up to disconnect the cable.
    • Repeat for the second antenna cable.
    • During reassembly, ensure that both antenna cables are reconnected at their appropriate connectors. The labels on the cables match the markings on the Wi-Fi module.
    • To reconnect each cable, align the connector directly over its socket, and then press down so it snaps into place.
  17. Steam Deck Motherboard Replacement, Disconnect the display: шаг 18, изображение 1 из 3 Steam Deck Motherboard Replacement, Disconnect the display: шаг 18, изображение 2 из 3 Steam Deck Motherboard Replacement, Disconnect the display: шаг 18, изображение 3 из 3
    • Use the pointed end of a spudger to lift up the small locking flap on the display cable's ZIF connector.
    • Use a pair of tweezers to slide the cable out of its connector.
    • Grip the cable by the pull tab, not by the cable itself.
  18. Steam Deck Motherboard Replacement, Disconnect the audio cable: шаг 19, изображение 1 из 2 Steam Deck Motherboard Replacement, Disconnect the audio cable: шаг 19, изображение 2 из 2
    • Use the pointed end of a spudger to lift up the small locking flap on the audio cable's ZIF connector.
  19. Steam Deck Motherboard Replacement: шаг 20, изображение 1 из 2 Steam Deck Motherboard Replacement: шаг 20, изображение 2 из 2
    • Grip the cable by its pull tab, not by the cable itself.
  20. Steam Deck Motherboard Replacement: шаг 21, изображение 1 из 3 Steam Deck Motherboard Replacement: шаг 21, изображение 2 из 3 Steam Deck Motherboard Replacement: шаг 21, изображение 3 из 3
    • Carefully peel the audio cable off of the battery.
    • The audio cable is secured to the battery with some light adhesive.
    • If the adhesive is stubborn, don't force the cable. Lightly heat the audio cable using an iOpener or a hair dryer to soften the adhesive.
  21. Steam Deck Motherboard Replacement, Disconnect the button board: шаг 22, изображение 1 из 3 Steam Deck Motherboard Replacement, Disconnect the button board: шаг 22, изображение 2 из 3 Steam Deck Motherboard Replacement, Disconnect the button board: шаг 22, изображение 3 из 3
    • Use the pointed end of a spudger to lift up the small locking flap on the button board cable's ZIF connector.
    • Grip the cable by the blue pull tab, not by the cable itself.
  22. Steam Deck Motherboard Replacement, Remove the motherboard screws: шаг 23, изображение 1 из 1
    • Use a Phillips driver to remove the three 3.7 mm screws securing the motherboard.
  23. Steam Deck Motherboard Replacement, Remove the motherboard: шаг 24, изображение 1 из 3 Steam Deck Motherboard Replacement, Remove the motherboard: шаг 24, изображение 2 из 3 Steam Deck Motherboard Replacement, Remove the motherboard: шаг 24, изображение 3 из 3
    • Remove the motherboard.
    • The audio and button board cables attach to the underside of the motherboard with ZIF connectors.
Заключение
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Steam Deck answers community for help.
3 участников успешно повторили данное руководство.
Carsten Frauenheim
Участник с: 03/10/20
92 688 Репутация
Автор 337 руководств
Команда
iFixit Участник iFixit
Community
141 членов
Автор 17 757 руководств
7 Комментариев
When will I be able to buy the motherboard?
Jing - Ответить
What is the actual size of the screws (M1.6, M2 , M2.2) as this information would be helpful if someone was to lose a screw while carrying out a repair or re paste.
Luis Elias castro - Ответить
Why Can't I buy this accessory?
ziyang - Ответить
Could we change dram or apu on the motherboard or upgrade thé motherboard ? Cause it s just zen2 and rdn2 .we need better performance and power !!!!
lapartdesanges50 - Ответить
Neither the ram or the APU are replacable. This is about the most powerful of an APU you can get in this formfactor, while not getting abysmal battery life
MJ26 Gaming -
Добавить комментарий
Просмотр статистики:
За последние 24часов: 53
За последние 7 дней: 375
За последние 30 дней: 1,840
За всё время: 26,250
