Steam Deck Right Trigger Replacement
Выберете то, что вам нужно
  1. Steam Deck Right Trigger Replacement, Prepare your device: шаг 1, изображение 1 из 3 Steam Deck Right Trigger Replacement, Prepare your device: шаг 1, изображение 2 из 3 Steam Deck Right Trigger Replacement, Prepare your device: шаг 1, изображение 3 из 3
    • Turn on your Steam Deck and allow the battery to discharge below 25% before starting your repairs, as a charged lithium-ion polymer battery can be dangerous if accidentally punctured.
    • As an extra precaution, Valve recommends putting your Steam Deck into battery storage mode within the BIOS before starting any internal repairs. Read how to do that here.
    • Power down your Steam Deck and unplug any cables.
    • If you have a microSD card installed, make sure to remove it before opening the Steam Deck. If you attempt to remove the back cover with it still installed, it could snap right in half.
    • During your repair, it can be helpful at times to lay the Steam Deck face-down into its case to protect the thumbsticks and prevent wobble.
    • Use a Phillips driver to remove the eight screws securing the back cover:
    • Four 9.5 mm screws
    • Four 5.8 mm screws
    • Despite the standards, Phillips screwdrivers can vary in size and shape—two drivers labeled as the same size may fit differently in the same screw. Use the size that fits the snuggest into the screw head.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your Steam Deck.
  2. Steam Deck Right Trigger Replacement, Unclip the back cover: шаг 3, изображение 1 из 2 Steam Deck Right Trigger Replacement, Unclip the back cover: шаг 3, изображение 2 из 2
    • Insert an opening pick into the thin gap between the back cover and the front shell, along the edge of the right grip.
    • If you're having trouble inserting your pick at the grip seam, try starting at either the top or bottom long edges first, then slide the pick towards the grip.
    • Pry up on the back cover to release it from the locking clips.
  3. Steam Deck Right Trigger Replacement, Remove the back cover: шаг 4, изображение 1 из 3 Steam Deck Right Trigger Replacement, Remove the back cover: шаг 4, изображение 2 из 3 Steam Deck Right Trigger Replacement, Remove the back cover: шаг 4, изображение 3 из 3
    • Once the clips are disconnected from one edge, the rest disconnect easily.
    • Grip the back cover at the opening you just created and pull it up and away from the device to unclip the long edges.
    • Remove the back cover.
  4. Steam Deck Right Trigger Replacement, Uncover the hidden shield screw: шаг 5, изображение 1 из 2 Steam Deck Right Trigger Replacement, Uncover the hidden shield screw: шаг 5, изображение 2 из 2
    • Use a pair of tweezers to remove the piece of foil tape covering the hidden screw on the board shield.
    • If possible, try not to rip or tear this tape so it can be reused. If necessary, you can fashion a replacement by cutting a piece of aluminum foil tape to fit.
  5. Steam Deck Right Trigger Replacement, Remove the shield screws: шаг 6, изображение 1 из 1
    • Use a Phillips driver to remove the three screws securing the board shield:
    • One 3.4 mm screw
    • Two 3.7 mm screws
  6. Steam Deck Right Trigger Replacement, Remove the shield: шаг 7, изображение 1 из 2 Steam Deck Right Trigger Replacement, Remove the shield: шаг 7, изображение 2 из 2
  7. Steam Deck Right Trigger Replacement, Disconnect the battery: шаг 8, изображение 1 из 3 Steam Deck Right Trigger Replacement, Disconnect the battery: шаг 8, изображение 2 из 3 Steam Deck Right Trigger Replacement, Disconnect the battery: шаг 8, изображение 3 из 3
    • Grip the battery cable by its pull tab and pull it directly away from the motherboard to disconnect it.
    • Alternatively, use the flat end of a spudger or a clean fingernail to gently push the connector out of its socket, then disconnect it completely by hand.
  8. Steam Deck Right Trigger Replacement, Unclip the right trigger: шаг 9, изображение 1 из 2 Steam Deck Right Trigger Replacement, Unclip the right trigger: шаг 9, изображение 2 из 2
    • The right trigger will be on your lefthand side when working on the Steam Deck, as it's laying upside down.
    • The Steam Deck's triggers clip into place on two pegs on the trigger bracket, which doubles as the hinge.
    • Place the flat end of a spudger onto the inside edge of the trigger's right clip.
    • Pivot the trigger clip out, away, and up from the peg to unlatch it.
    • During reassembly, latch the outermost peg first. Once in place, push down on the trigger to latch the innermost peg, producing an audible "click" sound.
    • Check to make sure that the trigger spring is properly aligned. Test the trigger action before continuing reassembly.
  9. Steam Deck Right Trigger Replacement, Remove the right trigger: шаг 10, изображение 1 из 2 Steam Deck Right Trigger Replacement, Remove the right trigger: шаг 10, изображение 2 из 2
    • Remove the right trigger.
    • Take care to not lose the trigger spring. It press-fits onto a peg on the trigger's underside.
  10. Steam Deck Right Trigger Replacement, Remove the trigger bracket screws: шаг 11, изображение 1 из 1
    • Use a Phillips driver to remove the three 5.2 mm screws securing the right trigger bracket.
  11. Steam Deck Right Trigger Replacement, Remove the trigger bracket: шаг 12, изображение 1 из 1
    • Remove the right trigger bracket.
    • Replacement triggers require calibration to work as expected. To calibrate new triggers, follow this calibration guide.
Заключение
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Steam Deck answers community for help.
2 участников успешно повторили данное руководство.
Carsten Frauenheim
Участник с: 03/10/20
92 688 Репутация
Автор 337 руководств
Команда
iFixit Участник iFixit
Community
141 членов
Автор 17 757 руководств
Один комментарий
This would be useful if you could actually find replacement triggers at all. I live in the UK, and cannot source these at all. I even contacted Valve about it and they cannot help me :(
Fil Sapia - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 24
За последние 7 дней: 188
За последние 30 дней: 836
За всё время: 10,319
