SteelSeries Arctis Pro Plus GameDAC Headset Circuit Board Replacement
Выберете то, что вам нужно
  1. SteelSeries Arctis Pro Plus GameDAC Headset Circuit Board Replacement, Headset Ear Cushions: шаг 1, изображение 1 из 2 SteelSeries Arctis Pro Plus GameDAC Headset Circuit Board Replacement, Headset Ear Cushions: шаг 1, изображение 2 из 2
    • Lift the edge of the cushion and pull out slightly.
    • Work your way around the cushion until it comes off completely.
    • Repeat for the other cushion.
  2. SteelSeries Arctis Pro Plus GameDAC Headset Circuit Board Replacement, Headset Circuit Board: шаг 2, изображение 1 из 1
    • Remove the three 5mm screws with a Phillips #0 driver head on the headphone with the microphone.
  3. SteelSeries Arctis Pro Plus GameDAC Headset Circuit Board Replacement: шаг 3, изображение 1 из 1
    • Lift the speaker off the headset to expose the circuit board.
    • Be careful not to lift the speaker too quickly or too forcefully to prevent the wires from being pulled out of their connections.
  4. SteelSeries Arctis Pro Plus GameDAC Headset Circuit Board Replacement: шаг 4, изображение 1 из 1
    • Remove the three 5mm screws using a Phillips #0 driver head.
  5. SteelSeries Arctis Pro Plus GameDAC Headset Circuit Board Replacement: шаг 5, изображение 1 из 1
    • Lift the circuit board out of the plastic housing.
    • Press in on the volume wheel while pulling on the circuit board to help maneuver the circuit board out of the housing.
Заключение
7 участников успешно повторили данное руководство.
Kyle Chang
Участник с: 01/24/19
1 152 Репутация
Автор 7 руководств
Команда
Cal Poly, Team S18-G1, White Winter 2019 Участник Cal Poly, Team S18-G1, White Winter 2019
CPSU-WHITE-W19S18G1
4 членов
Автор 21 руководств
3 Комментариев
any idea where i can buy the circuit parts to both side?
erminio santiago - Ответить
any idea where i can buy Circuit Board Replacement for both side? please
What's the problem that requires circuit board replacement? My left speaker doesn't work checked and all wires connected. Wondering if the circuit board fixes that
bayarea_rooter - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 12
За последние 30 дней: 89
За всё время: 9,204
