Введение
If your headset is loose this is the guide for you.
You can purchase a replacement for the ear cups and have a non dangling headset again.
Other than step 9 everything is quite easy if you’re able to solder cables.
Step 9 takes a bit of patience but it’s not too hard.
Выберете то, что вам нужно
Remove the ear pads by pulling gently from the bottom
Remove the Battery
Use the Torx T6 to remove the 6 screws holding both speakers ( Red Circles)
**Note for Reassembly at the end** That small gap circled in green is used to put the ear pads back on, insert the ring around the ear pad into that gap and spin the ear pad until you do a full circle.
Make sure the headset is unmuted before pulling up the board.
Pull up the board gently starting from zone 1 to 3
Insert a Plastic Spudger in the gap where you find zone 4 to gently push the board away from the casing. Make sure zone 1-3 are lifted.
Gently remove the black glue with a plastic spludger.
Then unsolder the cables circled
You can also unsolder the 2 cables that connect the speakers to the board but it’s not necessary for the repair.
Remove the C ring with the Circlip Pliers and the circular ring behind them on both earcups
Dont remove the bigger C shaped ring/block that’s on the right side
Pull out the cables to only have the ear cups shell left
Remove the volume knob with the spludger by inserting it in the arrow’s direction under the knob and gently pulling it up
Remove the spring bellow the volume knob
**For later** When reinstalling the headset you will notice that the knob has a flat line in the middle, you have to line it up with the flat side on the board.
On the 2 ear cup casing there should only be left the cable that connects to the battery and mic.
Remove the outer panel that covers the battery and the same outer plate on the other side.
This part is by far the most tedious of the fix
Inside the casing there should be multiple glue spots like the ones shown in the picture. I used a nail clipper with the shape of a plier to cut them in square shapes (like shown in the picture)
Use tweezers or something thin and sharp to gently pry open the battery inner panel
Use tweezers or something thin and sharp and insert the pointy side in the hole to push the inner panel
Unscrew the 2 screws with a Phillips 0
Untether the mic cable from the casing in Picture 2
Gently pull up the whole retractable mic mechanism. (Make sure the cable on the other side is loose so it can get pulled as you remove the entire mic)
Remove the battery connector (Sorry I don’t have a picture with the inner plate off but you just need to take it out)
On the Battery side at the bottom you’ll have to remove 2 small black plastic levers and a transparent small piece
Remove the glue circled in the picture (I don’t have a picture of the glue itself but it will be where it’s circled)
Remove the 2 small black pieces and the transparent one.
Reinstall everything in order except for the outer/inner panels and the battery.
When you make it back to Step 2 and complete it proceed to Step 15
Use superglue on the spots marked in green
Install the 4 magnets
Install the inner panel
Install the battery
Install the outer panel
Let the superglue do its thing for 15-30 minutes.
Enjoy your headset!
I made this guide months after I fixed mine, I don’t think I missed any steps but if something isn’t clear let me know and I will clarify.
If you have any questions don’t hesitate to ask. I’ll try to answer and edit the post if needed.
