SteelSeries Stratus XL Trigger Cleaning
Выберете то, что вам нужно
  1. SteelSeries Stratus XL Trigger Cleaning, SteelSeries Stratus XL Trigger Cleaning: шаг 1, изображение 1 из 1
    • Remove the battery cover and the batteries from the controller.
  2. SteelSeries Stratus XL Trigger Cleaning: шаг 2, изображение 1 из 1
    • Remove the eight 1 mm screws from the bottom of the controller using the Y1 Tri-Point screwdriver.
  3. SteelSeries Stratus XL Trigger Cleaning: шаг 3, изображение 1 из 1
    • Carefully pull the back of the controller off.
    • Be careful not to pull too hard damaging the wire connecting the two pieces inside.
  4. SteelSeries Stratus XL Trigger Cleaning: шаг 4, изображение 1 из 2 SteelSeries Stratus XL Trigger Cleaning: шаг 4, изображение 2 из 2
    • Locate the trigger arm pot depending on which side you are having issues with on your controller.
    • Depending on what issues you may be having with your controller, the screw in the arm pot may appear different. Push the trigger down a couple times and see what happens to the screw.
    • If your controller is registering phantom clicks without you pushing it, the screw may be a little too tight. Turning the screw slightly to the left may solve this issue.
    • If your controller is not registering when you push the trigger, the screw may be a little loose. Turning the screw slightly to the right may solve this issue.
  5. SteelSeries Stratus XL Trigger Cleaning: шаг 5, изображение 1 из 1
    • Make minor adjustments to the screw inside the arm pot using your flathead screwdriver.
  6. SteelSeries Stratus XL Trigger Cleaning: шаг 6, изображение 1 из 1
    • Dip your Q-tip in a bit of isopropyl alcohol and dab a little bit into the arm pot. Be careful not to let any leak over any other parts of the controller.
Заключение
To reassemble your device, follow the instructions in reverse order.
Jeffrey Zeng
Участник с: 03/22/21
133 Репутация
1 руководство автора
Команда
UMass Dartmouth, Team S1-G25, Riel Spring 2021 Участник UMass Dartmouth, Team S1-G25, Riel Spring 2021
UMASSD-RIEL-S21S1G25
1 член
Автор 1 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 4
За последние 7 дней: 27
За последние 30 дней: 112
За всё время: 2,373
