Steelseries Rival 700 Gaming Mouse Sensor Assemby Replacement
Выберете то, что вам нужно
  1. Steelseries Rival 700 Gaming Mouse Sensor Assemby Replacement, Disconnect the mouse from your computer: шаг 1, изображение 1 из 2 Steelseries Rival 700 Gaming Mouse Sensor Assemby Replacement, Disconnect the mouse from your computer: шаг 1, изображение 2 из 2
    • To avoid electronically damaging either your computer or your mouse, unplug the usb cable from its socket.
  2. Steelseries Rival 700 Gaming Mouse Sensor Assemby Replacement, Disconnect the cable from the mouse: шаг 2, изображение 1 из 3 Steelseries Rival 700 Gaming Mouse Sensor Assemby Replacement, Disconnect the cable from the mouse: шаг 2, изображение 2 из 3 Steelseries Rival 700 Gaming Mouse Sensor Assemby Replacement, Disconnect the cable from the mouse: шаг 2, изображение 3 из 3
    • The Rival 700 mouse is a non wireless mouse. The micro-USB cable end is an elbow socket, secured by a plastic clip.
    • To disconnect the cable from the mouse, firmly press the plastic clip using your thumb
  3. Steelseries Rival 700 Gaming Mouse Sensor Assemby Replacement, Nameplate removal: шаг 3, изображение 1 из 2 Steelseries Rival 700 Gaming Mouse Sensor Assemby Replacement, Nameplate removal: шаг 3, изображение 2 из 2
    • The original nameplate is a soft rubber one that can be removed just by pulling it softly out of its socket.
    • WARNING: When reassembling, if you're using a custom nameplate that may not be as stretchable as the original one, insert it softly, and use a lime tool on the new part to avoid damaging the mouse socket.
  4. Steelseries Rival 700 Gaming Mouse Sensor Assemby Replacement, Nameplate printing: шаг 4, изображение 1 из 1
    • You will be able to download the 3D files to design a custom nameplate on the Steelseries website. The link is also provided in the part description.
    • On this picture, the original "RIVAL" nameplate will be replaced with a new one on which i just had my Twitch ID printed.
    • Be creative, use colored plastic, put logos and drawings on your mouse.
  5. Steelseries Rival 700 Gaming Mouse Sensor Assemby Replacement, Top cover removal: шаг 5, изображение 1 из 3 Steelseries Rival 700 Gaming Mouse Sensor Assemby Replacement, Top cover removal: шаг 5, изображение 2 из 3 Steelseries Rival 700 Gaming Mouse Sensor Assemby Replacement, Top cover removal: шаг 5, изображение 3 из 3
    • Use both your index and thumb to gently pry the top cover out from the mouse.
    • This part is a thin plastic one which needs a certain amount of strength to be removed. Be careful not to break it.
  6. Steelseries Rival 700 Gaming Mouse Sensor Assemby Replacement, Top cover replacement: шаг 6, изображение 1 из 1
    • Steelseries sells a set of two different covers to replace the original one, with a sweat-resistant one f.e.
    • Check the parts section for the purchase link.
    • On the left, you can see on the wide led slot that is used to color the Steelseries logo on your mouse.
  7. Steelseries Rival 700 Gaming Mouse Sensor Assemby Replacement, Sensor screws: шаг 7, изображение 1 из 2 Steelseries Rival 700 Gaming Mouse Sensor Assemby Replacement, Sensor screws: шаг 7, изображение 2 из 2
    • Use a Philips #0 screwdriver to remove the four screws that are keeping the mouse sensor assembly sealed.
  8. Steelseries Rival 700 Gaming Mouse Sensor Assemby Replacement, Sensor removal: шаг 8, изображение 1 из 1
    • Insert your thumb and index in the two mouse holes and gently pry the sensor assembly out from its socket.
Заключение
3 участников успешно повторили данное руководство.
Vincent Monteil
Участник с: 07/06/13
6 975 Репутация
Автор 19 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 5
За всё время: 1,693
