Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Hello this guide is to be used for sticking keys on a saxophone; however, this guide should be used as a last resort if cleaning the pad on the key did not solve the problem. Most sticking keys can be solved easily by simply cleaning the pad, but in extreme cases it may be deemed necessary to loosen the key itself.
Выберете то, что вам нужно
Loosen screw until key moves freely or as desired. Once as desired, you are then ready to play the instrument and test out key!
Один комментарий
An Issue I have with a sticky key on my Alto Saxophpone. I found a remedy on ifixit.com, a hack recommended for fixing pretty much anything! Try it out!!
