Введение
This guide will demonstrate how to remove and replace a broken or bent arm of a Straight Leg Canopy Tent. There are 16 individual arms that allow for the tent to fully extend and open. Prior-knowledge skills useful to complete this task would be how to properly use a Phillips screwdriver and a wrench. Before starting this fix, the canopy cover should be removed for easy access of the joints and the tent should be standing and opened.
Выберете то, что вам нужно
Use the wrench to hold the nut in place.
Use the Phillips screwdriver to unscrew the screw.
Repeat step 1 for the other two joints.
Hold the nut in place and finish unscrewing the screw.
Place the screw through the hole and twist the nut on the backside of the screw.
Hold the nut with the wrench while you screw the screw to make it tight.
At the middle joint, place the screw through the hole in the black plastic connector and through the conjoining arms.
Use the Phillips screwdriver to tighten the screw in place.
After following these instructions in chronological order, the end result would be for the successful removal and replacement of an arm on a Straight Leg Canopy Tent.
Еще один человек закончил это руководство.
