Введение
Battery acid damage is a common issue that can occur in electronic devices like K-pop light sticks. Left unaddressed, it can degrade performance and render the light stick inoperable. This guide will identify and repair battery acid damage on a Stray Kids V.1 light stick and how to prevent further damage and ensure device longevity.
Выберете то, что вам нужно
Unscrew the battery chamber and remove the batteries.
Inspect the battery chamber for signs of corrosion. Pay attention to areas around the battery socket and terminals. As shown in the picture, these red arrows are the areas we will focus on.
To make diluted vinegar in a measuring cup mix equal parts water and vinegar. I used ½ cup water and ½ cup vinegar.
Dip a cotton swab or soft cloth into the vinegar solution and gently wipe the corroded areas on the light stick.
Let the solution sit for 5-15 minutes to break down the battery acid residue.
Use a clean, damp cloth to wipe away the residue. Repeat as needed until the corrosion is removed.
Ensure the light stick is completely dry with a paper towel before inserting new batteries. Moisture can cause further damage to electronic components.
Use a toothbrush or cotton swab to gently scrub the corroded areas of the battery holder. Be careful not to apply too much pressure to avoid damaging the plastic or metal components.
Dry the battery holder with a small cloth to air dry completely before reinserting batteries or using it in a device.
Check the battery holder for any remaining signs of damage or remaining corrosion.
If the battery holder is damaged consider replacing the battery holder by getting a replacement on Amazon or a rechargeable battery.
Rechargeable batteries are less likely to leak and can be reused multiple times.
Regular maintenance and prompt action are essential for preserving the performance and longevity of your Stray Kids V.1 light stick. Following these steps and taking preventative measures can effectively address battery acid damage and ensure the continued enjoyment of your favorite K-pop accessory.
Don’t forget to take out the batteries in your light stick after a concert.
