Введение
This guide will show you hot to replate the safety switch on the Sublue WhiteShark Mix Underwater Scooter.
Press the push button in while sliding the planner towards the back of the device to remove the battery panel.
Remove the ten Phillips screws on the bottom of the device. Remove the bottom panel.
Place the main body panel with the handle that holds the safety switch towards you. Pull the white tab of the right and pull towards you from the top of the safety switch.
