Введение
Use this guide to replace your back wheel on your Summer Infant 3D Lite stroller.
Set the stroller up so the front wheel is on the ground with the metal push tab up.
Push the tab in with your finger enough so the plastic can slip out above the tab.
OPTIONAL: If the tab is being difficult, use a key to push the tab in further in order to slip plastic out of place.
The wheel should slide right off the pole once the tab is pushed out of place. It is now possible to make repairs or replace the wheel completely.
4 участников успешно повторили данное руководство.
2 Комментариев
Gd, have a question . Were can u buy spare parts for this type of stroller?
Can you tell me if you have a rear wheel that will fit a summer 3D go convenience stroller all black?
