Sunbeam Snow Cone Maker Motor Replacement
Выберете то, что вам нужно
  1. Sunbeam Snow Cone Maker Motor Replacement, Dasher: шаг 1, изображение 1 из 1
    • Push the button on the back to release the lid. (Missing on this example device.)
    • In the photo on the device page it is red.
  2. Sunbeam Snow Cone Maker Motor Replacement: шаг 2, изображение 1 из 2 Sunbeam Snow Cone Maker Motor Replacement: шаг 2, изображение 2 из 2
    • Unscrew the dasher by holding it in the middle and turning clockwise.
    • You will have to spin it quite a bit.
    • Remove the dasher.
    • Alternately, you can continue to step 3 to further disassemble the dasher components.
  3. Sunbeam Snow Cone Maker Motor Replacement: шаг 3, изображение 1 из 2 Sunbeam Snow Cone Maker Motor Replacement: шаг 3, изображение 2 из 2
    • To take the dasher apart, remove the three 5.5 mm Phillips #00 screws embedded in the plastic. **The 3rd screw is behind the hand in the picture
    • Carefully pull the two pieces apart.
    • When you've finished taking apart the dasher, you should have two parts that are shown in the second picture in this step.
  4. Sunbeam Snow Cone Maker Motor Replacement, Motor: шаг 4, изображение 1 из 1
    • After removing the dasher, turn the device so that you can see the “lock” and “unlock” symbols on the back.
    • Twist the casing so that it is in the unlocked position and remove it from the bottom half of the machine.
  5. Sunbeam Snow Cone Maker Motor Replacement: шаг 5, изображение 1 из 2 Sunbeam Snow Cone Maker Motor Replacement: шаг 5, изображение 2 из 2
    • Unscrew the five screws and remove the piece labeled in the picture. You should now be able to see the motor.
  6. Sunbeam Snow Cone Maker Motor Replacement: шаг 6, изображение 1 из 1
    • Lay the device on its side.
    • Remove the 4 gray rubber “feet” by pulling them straight off.
    • Remove the four 5.5 mm Phillips #00 screws that are under them.
    • Remove the bottom plastic cover.
  7. Sunbeam Snow Cone Maker Motor Replacement: шаг 7, изображение 1 из 1
    • Remove the two 5.5 mm Phillips #00 screws holding a bracket to keep the cord in place.
    • Remove the the bracket so the chord has room to move.
  8. Sunbeam Snow Cone Maker Motor Replacement: шаг 8, изображение 1 из 3 Sunbeam Snow Cone Maker Motor Replacement: шаг 8, изображение 2 из 3 Sunbeam Snow Cone Maker Motor Replacement: шаг 8, изображение 3 из 3
    • Remove the topmost two 5.5 mm Phillips #00 screws that hold the motor in the case.
    • Remove and replace the motor.
Заключение
Еще один человек закончил это руководство.
Kirsty van Dam
Участник с: 03/24/15
119 Репутация
1 руководство автора
Команда
University of Alabama, Team 1-5, Naidoo Spring 2015 Участник University of Alabama, Team 1-5, Naidoo Spring 2015
UA-NAIDOO-S15S1G5
4 членов
Автор 2 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 9
За последние 30 дней: 11
За всё время: 1,078
