Super Nintendo Super Nintendo Outer Case Replacement
Выберете то, что вам нужно
  1. Super Nintendo Super Nintendo Outer Case Replacement, Outer Case: шаг 1, изображение 1 из 1
    • Remove the six screws located on the underside of the system using the Gamebit 4.5mm screwdriver.
    In order to prevent damage to the fuse, make sure that you always cycle the power before doing so with the power supply disconnected.
    Raucedine - Ответить
    There is a step missing from these instructions. There are two philips head screws where the AV/Power ports are on the back of the motherboard that need to be removed before you can remove the motherboard itself.
    phoenixknight8082 - Ответить
    I replaced my controller port, thinking that it was the culprit, but my SNES is still having issues. Nothing works for controller port 1 and only a few buttons work for controller port 2. I tried switching out the controllers and the issue seems to be isolated to the SNES itself. Does anyone have any other suggestions for fixing my issue?
    Thanks in advance.
    Mike Watts - Ответить
    For those facing a black screen on startup (after having cleaned pins on cartridges and cartridge slot) WITH power light coming on, turn off console, remove power, and try shorting out the capacitor leads. My SNES stopped working suddenly after a single power cycle, and shorting out the leads (while UNPOWERED) revived it.
    Austin Barnett - Ответить
    Could you further explain how to short the capacitor leads?
    Will Pulman -
  2. Super Nintendo Super Nintendo Outer Case Replacement: шаг 2, изображение 1 из 3 Super Nintendo Super Nintendo Outer Case Replacement: шаг 2, изображение 2 из 3 Super Nintendo Super Nintendo Outer Case Replacement: шаг 2, изображение 3 из 3
    • Carefully flip the unit back over.
    • Locate the seam. Lift and separate the upper half of the case from the lower half of the case.
Заключение
20 участников успешно повторили данное руководство.
Cameron Deines
Участник с: 10/05/10
700 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 4-47, Amido Fall 2010 Участник Cal Poly, Team 4-47, Amido Fall 2010
CPSU-AMIDO-F10S4G47
4 членов
Автор 25 руководств
Один комментарий
Hi, my name is Orlando, I'm writting of Perú, I have a question:
I can´t put the hinge of the top of that above part.
Please, can you help me, my mail is orla.davila12@gmail.com
Orlando Dávila Vizconde - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 5
За последние 7 дней: 36
За последние 30 дней: 177
За всё время: 28,450
