Введение
This guide will simply show you how to remove the back cover of the device. Very minimal effort is required to achieve this task.
Выберете то, что вам нужно
Wedge the plastic opening tool between the back cover of the device and the front panel.
You will hear a snapping sound as the cover is separated from the body of the device.
Slide the opening tool along the seam between the front panel and the back cover to un-clip the remaining connections around the device.
Again, you will hear a snapping sound as the cover is separated from the body of the device.
Lift the back cover from the body of the device to expose the internal components.
Еще один человек закончил это руководство.
