Введение
In this guide you will have to remove the back cover of the device to locate and replace the FM antenna.
Because this task requires the use of a soldering iron, prior experience with soldering/desoldering will be beneficial.
Выберете то, что вам нужно
Wedge the plastic opening tool between the back cover of the device and the front panel.
You will hear a snapping sound as the cover is separated from the body of the device.
Slide the opening tool along the seam between the front panel and the back cover to un-clip the remaining connections around the device.
Again, you will hear a snapping sound as the cover is separated from the body of the device.
Lift the back cover from the body of the device to expose the internal components.
Remove the Battery
The battery is secured to the back panel with tape and glue.
Peel back the tape around the battery and discard it.
Tear through the adhesive holding the battery by using the spudger tool.
Desolder the 2 Battery Wires
The Battery has two wires connected to the motherboard (one black and one red).
Еще один человек закончил это руководство.
