Введение
In this guide you will remove the back cover of the device and disconnect the motherboard from the surrounding components. You will then unscrew the motherboard from the device and replace it if need be.
Because this task requires the use of a soldering iron, prior experience with soldering/desoldering will be beneficial.
Выберете то, что вам нужно
Wedge the plastic opening tool between the back cover of the device and the front panel.
You will hear a snapping sound as the cover is separated from the body of the device.
Slide the opening tool along the seam between the front panel and the back cover to un-clip the remaining connections around the device.
Again, you will hear a snapping sound as the cover is separated from the body of the device.
Lift the back cover from the body of the device to expose the internal components.
Remove the Battery
The battery is secured to the back panel with tape and glue.
Peel back the tape around the battery and discard it.
Tear through the adhesive holding the battery by using the spudger tool.
Desolder the 2 Battery Wires
The Battery has two wires connected to the motherboard (one black and one red).
Remove the two Phillips #00 screws attaching the housing of the camera to the device.
Follow the camera unit back to the motherboard.
Use the spudger tool to remove the camera.
Remove the Speakers
Use the tweezers to remove the speakers from their compartments.
Remove the large ribbon cable from the socket that attaches it to the motherboard.
Pull down on the dark grey sliders located on both sides of the ribbon cable to release it.
Remove the small ribbon cable from the socket that attaches it to the motherboard.
Flip the dark grey latch to release the ribbon cable from the motherboard.
Еще один человек закончил это руководство.
