Supercycle SC1800 Tire Replacement
Выберете то, что вам нужно
  1. Supercycle SC1800 Tire Replacement, Tire: шаг 1, изображение 1 из 1
    • Deflate the tire by pressing the valve stem in.
    • If it's difficult to press the stem in with your hands, use a plastic wedge tool.
  2. Supercycle SC1800 Tire Replacement: шаг 2, изображение 1 из 1
    • Once the tire is deflated, press the beading inside until it is removed from the rim.
    • If you need to replace your rim, do it now.
  3. Supercycle SC1800 Tire Replacement: шаг 3, изображение 1 из 1
    • Slide the plastic wedge tool under the beading of the tire, and pull it outwards.
    • The tool is not required, but it makes the job easier.
    • Once the tire is removed from the rim on one side, do the same to other side.
    • Make sure not to puncture the tire tube, as you will need that for the new tire.
  4. Supercycle SC1800 Tire Replacement: шаг 4, изображение 1 из 2 Supercycle SC1800 Tire Replacement: шаг 4, изображение 2 из 2
    • Pull out the tire tube from the tire and transfer it into the new tire.
    • Make sure the valve is facing towards the center as shown in the second picture.
    • If you must replace your tire tube, do it now.
  5. Supercycle SC1800 Tire Replacement: шаг 5, изображение 1 из 1
    • Once the tube is in place, use a little bit of force to get the beading into the rim, making sure the valve goes through the designated hole in the rim.
    • If it starts getting difficult to push the beading with your hands, use the plastic wedge tool to finish.
    • It is important for the valve to correctly line with the valve hole first. Otherwise, you risk damaging the tire tube.
  6. Supercycle SC1800 Tire Replacement: шаг 6, изображение 1 из 1
    • Do the same to both sides of the beading. You will need to use the plastic tool for the other side.
  7. Supercycle SC1800 Tire Replacement: шаг 7, изображение 1 из 1
    • Re-inflate the tire.
    • It may be difficult to re-inflate due to the folds in the deflated tire tube. Be patient!
Финишная черта
Еще один человек закончил это руководство.
Firuz Khandakar
Участник с: 09/19/20
195 Репутация
1 руководство автора
Команда
York University, Team S2-G7, Melo-Thaiss Fall 2020 Участник York University, Team S2-G7, Melo-Thaiss Fall 2020
YORK-MELO-THAISS-F20S2G7
1 член
Автор 2 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 8
За последние 30 дней: 35
За всё время: 927
