Введение
In this replacement guide, we will show you how to remove and replace the motherboard in your tablet. This will require some soldering so be sure to have your soldering kit warmed up and your safety goggles on.
Выберете то, что вам нужно
Use the plastic opening tool to separate the screen from the back cover.
Use the tweezers to lift the tab shown in the picture, and remove the orange ribbon from it gently. Repeat for all three ribbons on the device.
Use the Phillips 1.5 mm screwdriver (Phillips #000) to unscrew the green motherboard from the body at the three points
Use a hot soldering tool to desolder the wires connecting the motherboard to the speaker. Desolder the wires connecting the motherboard to the battery.
Red: Speakers
Orange: Battery
Yellow: LED
Еще один человек закончил это руководство.
