Введение
This guide will demonstrate how to replace your devices Fans. This guide is quick and simple. It will only take you 15-20 min and only uses a few tools. You might need to replace your devices fans if you can't hear them and your device is getting hot.
If the fans are spinning under load, use an ESD-safe brush to clean out the blades and remove any built-up debris.
Выберете то, что вам нужно
Disconnect the battery cable by lifting the pull tab until it "clicks."
Flip up the ZIF locking flap on each socket.
Disconnect the ribbon cables attached to each fan.
3 Комментариев
Any idea where to buy the parts?
Any luck in getting the fan replacement part?
Same question, where I can buy those cover plastic stuff.
