Введение
This is a guide to replace the SSD in a Microsoft Surface Laptop Studio. You may need to replace the SSD if your computer is slower opening or using files. A bad SSD may also cause files to disappear. This is a very simple guide that only requires a few tools. It should only take 15-20 minutes.
Выберете то, что вам нужно
Disconnect the battery cable by lifting the pull tab until it "clicks."
After removing the devices battery, locate the SSD next to the mother board.
2 участников успешно повторили данное руководство.
3 Комментариев
I tried the SSD upgrade with two different WD products (1TB black and 1TB blue) and with both I had problems: Random blue screens and after some time, computed could not find the SSD anymore. Looks like it has something to do with drive consuming too much power but I am not sure. I am now back on original 256 GB SSD, since I can't find what is causing compatibility issues.
Try this, it will help.
