Введение
Do you want a bigger SSD or perhaps a faster PCIe NVMe SSD? Follow this guide to replace your SSD.
(Note: Surface Studio with Intel Core i5 comes with SATA III SSD while Surface Studio with Intel Core i7 comes with PCIe NVMe SSD.)
Выберете то, что вам нужно
Lay the Surface face down on a padded surface
Remove the four rubber feet at each corner concealing the Torx screws
Remove the four Torx screws under the rubber feet.
Two screws on the upper corners are longer than two screws on the lower corners.
Attach suction cups to the bottom cover and then pull on the suction cups to free the bottom cover.
Remove five torx screws holding the two fans to the midframe
Remove the two fans
Remove four large torx screws holding the midframe
Remove four small torx screws holding the midframe
Slowly remove the midframe
Detach the connectors for the two fans and the speaker
With the midframe removed, the M.2 SSD is now accessible
Remove a torx screw holding the M.2 holding the SSD to the motherboard
Pull the SSD straight back
6 участников успешно повторили данное руководство.
21 Комментариев
I know that one of the very first questions would be: Does the M.2 slot supports PCIe NVMe ?
The answer is: Yes it does.
But it does not mean that you can get the drive to run in NVMe model.
There does not appear to be a setting to enable NVMe model for the drive.
John -
Does it support bootable NVMe?
Sure. When installing Windows, choose to install Windows to "Drive 1" instead of "Drive 0"
Is there any raid options that need to be configured?
