Surface Studio Motherboard Replacement
Выберете то, что вам нужно
  1. Surface Studio Motherboard Replacement, Motherboard: шаг 1, изображение 1 из 3 Surface Studio Motherboard Replacement, Motherboard: шаг 1, изображение 2 из 3 Surface Studio Motherboard Replacement, Motherboard: шаг 1, изображение 3 из 3
    • Lay the Surface face down on a padded surface
    • Be careful not to scratch the screen when laying it face down
    • Remove the four rubber feet at each corner concealing the Torx screws
    • Remove the four Torx screws under the rubber feet.
    • Two screws on the upper corners are longer than two screws on the lower corners.
    • Attach suction cups to the bottom cover and then pull on the suction cups to free the bottom cover.
  2. Surface Studio Motherboard Replacement: шаг 2, изображение 1 из 2 Surface Studio Motherboard Replacement: шаг 2, изображение 2 из 2
    • Remove five torx screws holding the two fans to the midframe
    • Remove the two fans
    • The fan connectors are behind the midframe and not yet accessible. Let the fans hang loosely until you can access the connectors.
    • Four large torx screws and four small torx screws hold the midframe to the upper frame.
    • Remove four large torx screws holding the midframe
    • Remove four small torx screws holding the midframe
  3. Surface Studio Motherboard Replacement: шаг 3, изображение 1 из 1
    • Slowly remove the midframe
    • Be careful: the speaker on the midframe is still attached to the motherboard
    • Detach the connectors for the two fans and the speaker
  4. Surface Studio Motherboard Replacement: шаг 4, изображение 1 из 3 Surface Studio Motherboard Replacement: шаг 4, изображение 2 из 3 Surface Studio Motherboard Replacement: шаг 4, изображение 3 из 3
    • Remove four spring loaded torx screw labeled 1 to 4
    • Remove four torx screw labeled 5 to 7
    • Remove 5mm hex mounting post
    • Use a spudger to remove the heatsink assembly from the motherboard
  5. Surface Studio Motherboard Replacement: шаг 5, изображение 1 из 2 Surface Studio Motherboard Replacement: шаг 5, изображение 2 из 2
    • Remove three torx screws holding the hard drive brackets
    • Remove the hard drive and disconnect the SATA/SATA power cable
  6. Surface Studio Motherboard Replacement: шаг 6, изображение 1 из 3 Surface Studio Motherboard Replacement: шаг 6, изображение 2 из 3 Surface Studio Motherboard Replacement: шаг 6, изображение 3 из 3
    • Lift the black plastic flap attached to the data cable retainer and rotate it away from motherboard.
    • Pull the data cable out of its socket.
    • The data cable socket is very fragile. Do not lift the connector upward as you disconnect it, as the socket may break off the motherboard. Pull the cable parallel to the face of the motherboard.
    • Disconnect the data cable connecting the headphone jack to the SD card slot modular board
    • Remove three torx screws holding the SD card slot modular board
    • Remove the SD card slot modular board
    • Remove a torx screw holding the headphone jack
    • Remove the headphone jack
  7. Surface Studio Motherboard Replacement: шаг 7, изображение 1 из 2 Surface Studio Motherboard Replacement: шаг 7, изображение 2 из 2
    • Although removing the power supply is not necessary, it makes accessing the connectors easier
    • Remove a Phillips screw still retaining the power supply
    • Remove a torx screw retaining the power supply cable
    • Unplug the power supply from the motherboard
    • Lift the power supply up and away from the base unit
  8. Surface Studio Motherboard Replacement: шаг 8, изображение 1 из 2 Surface Studio Motherboard Replacement: шаг 8, изображение 2 из 2
    • Remove three torx screws holding the motherboard
    • Lift the motherboard up and away from the base unit.
  9. Surface Studio Motherboard Replacement: шаг 9, изображение 1 из 1
    • Remove three 5mm hex mounting posts
Заключение
7 человек успешно провели ремонт по этому руководству.
The Raptor
Участник с: 11/27/16
6 276 Репутация
Автор 6 руководств
3 Комментарии к руководству
Is it possible to DIY to use a full fledged PC tower with this screen? The display would be extremely useful for digital painting and 3d sculpting beyond the life of the computer hardware.
John - Ответить
Where can just the mainboard be found? Did some searches on amazon and ebay to no avail. Is there a part number to the i7, 16GB 1TB version that can be looked up?
pikarde - Ответить
I would like to find a new motherboard too… 32gb ram though.
Roger Owens - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 12
За последние 30 дней: 52
За всё время: 5,453
