Введение
Follow this guide to replace your power supply unit
Выберете то, что вам нужно
Lay the Surface face down on a padded surface
Remove the four rubber feet at each corner concealing the Torx screws
Remove the four Torx screws under the rubber feet.
Two screws on the upper corners are longer than two screws on the lower corners.
Attach suction cups to the bottom cover and then pull on the suction cups to free the bottom cover.
Remove five torx screws holding the two fans to the midframe
Remove the two fans
Remove four large torx screws holding the midframe
Remove four small torx screws holding the midframe
Slowly remove the midframe
Detach the connectors for the two fans and the speaker
Remove four spring loaded torx screw labeled 1 to 4
Remove four torx screw labeled 5 to 7
Remove 5mm hex mounting post
Use a spudger to remove the heatsink assembly from the motherboard
Remove three torx screws holding the hard drive brackets
Remove the hard drive and disconnect the SATA/SATA power cable
Remove a Phillips screw still retaining the power supply
Remove a torx screw retaining the power supply cable
Unplug the power supply from the motherboard
Lift the power supply up and away from the base unit
5 участников успешно повторили данное руководство.
3 Комментариев
Does anyone have a source for a new power supply?
