Введение
This explains what will be necessary to not only replace the back panels, but also open the SwagTron T1 to have access to other parts.
Выберете то, что вам нужно
Unscrew the eighteen 10mm screws that secure the back panels using a Phillips #2 screwdriver.
Carefully lift the panels off
Follow the wires from the panels to the motherboard.
You may need to cut any zip ties that are holding the wires together.
There is one connection on the battery side and three on the other side that must be removed.
Your back panels are now completely removed.
