Введение
This guide will show you where to unscrew, how to split the device apart, and then how to disconnect a failing battery from the rest of the interior electronics.
Запчасти
  1. Unscrew seven 17.95 mm screws on the side of the device. Unscrew the 13.87 mm screw.
    • Unscrew seven 17.95 mm screws on the side of the device.
    • Unscrew the 13.87 mm screw.
  2. Find the sticker on the back of the device. It may have already been removed.
    • Find the sticker on the back of the device. It may have already been removed.
    • If there is a sticker, peel it back from either half of the device.
  3. Firmly, but carefully grip each half of the case and split it open. Firmly, but carefully grip each half of the case and split it open.
    • Firmly, but carefully grip each half of the case and split it open.
  4. Remove the silver-colored battery cap from the top of the battery.
    • Remove the silver-colored battery cap from the top of the battery.
  5. Lift the attached battery from the device and place it on the surface.
    • Lift the attached battery from the device and place it on the surface.
    • Remove the second silver-colored battery cap from the bottom of the interior of the device.
  6. Using the spudger, apply pressure to the lock on the black wire attachment.
    • Using the spudger, apply pressure to the lock on the black wire attachment.
    • While pressure is being applied to the lock, pull the black wire away from the battery.
  7. Using the spudger, apply pressure to the lock on the red wire attachment. While pressure is being applied to the lock, pull the red wire away from the battery.
    • Using the spudger, apply pressure to the lock on the red wire attachment.
    • While pressure is being applied to the lock, pull the red wire away from the battery.
    • When installing the new battery, you do not need to press down on the locks. Simply plug the wires into the appropriate sockets on the new battery.
Заключение
12 участников успешно повторили данное руководство.
Alexander Boesenberg
Участник с: 22.09.2014
682 Репутация
Автор 3 руководств
Команда
USF Tampa, Team 10-3, Brown Fall 2014 Участник USF Tampa, Team 10-3, Brown Fall 2014
USFT-BROWN-F14S10G3
3 членов
Автор 5 руководств
Комментариев: 9
This seems very easy. Will try amd make an update
eli3danimator - Ответить
This was helpful but my swiffer vacuum had a plastic chassis for the battery and I had to remove the circuit board as well to route the wires on my replacement battery as they were not is the same places as the factory battery.
lillysilbert - Ответить
Where do you purchase the batteries
deniseward640 - Ответить
Where do you purchase the batteries?
One place you can get the battery pack as shown is here; https://sweeperbattery.com/. The latest model (easier to install) battery in a case (6 cell - 7.2 volt) is also available from amazon.
Dwight Cooper - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 11
За последние 7 дней: 88
За последние 30 дней: 421
За всё время: 50,862
