Введение
This guide uses incorrect tools. Use an ESD safe tool, such as a nylon spudger, to complete steps that involve delicate internal components.
Выберете то, что вам нужно
Remove ten 7mm Phillips #0 screws.
Remove four 5mm Phillips #0 screws.
Wedge head lightly between drive and bottom of tab.
Repeat on both sides.
Gently pull out ribbon
Follow the red and black cables to the motherboard point of attachment.
Use a Flat head screwdriver.
Place head of driver into the grove of plug and port.
Wedge on all sides evenly to work out plug slowly.
Remove small and large plugs.
Anchor screw removal
Use Philip's head screwdriver
Place head of driver into screw on mother board.
Rotate counter clockwise
Remove all four screws
