Введение
This guide uses incorrect tools. Use an ESD safe tool, such as a nylon spudger, to complete steps that involve delicate internal components.
Выберете то, что вам нужно
Remove ten 7mm Phillips #0 screws.
Remove four 5mm Phillips #0 screws.
Disconnect ribbon
Rotate screwdriver to peel sticker from ribbon.
Place spudger head behind gray tabs on port.
Press outward to disengage tab.
Repeat on other side.
Slide out ribbon.
Using Philips head screwdriver, remove the two 7 mm screws.
Slide off top panel.
