Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Before disassembling the quadcopter, find out which motor(s) need to be replaced.
Rotate your quadcopter until the front of the quadcopter is facing you, or the side opposite of the charger hole.
Remember where the motor(s) that needs replacement in relativity to the charger port.
Once you have designated broken motor take of all propellers in a pulling twisting motion.
After all propellers are off the quadcopter flip the quadcopter over and unscrew the undercarriage from the body to reveal circuitboard and motors.
For this step you will need to have a small Phillips head screwdriver.
Remove the motor shell and body cover from the four motors revealing circuitboard and the motors compleatly.
After separate these parts this makes it easier to reconstruct the quadcopter.
2 участников успешно повторили данное руководство.
