Введение
If you are running into memory issues with your T-Mobile Huawei Prism U8651T, installing or replacing an SD card may be necessary. This guide will show how to install/replace the SD card in your phone.
Place the phone face down.
Slide the back cover panel away from you, until you hear a click.
Lift the back cover panel.
Locate the SD card port.
Orient the SD card as shown.
Insert the SD card into the SD card port.
4 участников успешно повторили данное руководство.
