Введение
This will take you step-by-step through the process, regardless of whether your existing screen protector is damaged or scratched, or if you just want to change the look of your device. To guarantee a seamless and effective screen protector replacement, follow these instructions.
Выберете то, что вам нужно
Begin by turning off your TCL 30Z and finding a clean, well-lit workspace. Gather all necessary tools and materials.
Use a plastic pry tool to gently lift one corner of the existing screen protector. Gradually peel it off, applying slight pressure to release any adhesive. Note: Be careful not to damage the screen or any surrounding components during this process.
Инструмент, используемый на этом этапе:Microfiber Cleaning Cloths$3.99
Wipe the screen with a microfiber cloth to remove any smudges or fingerprints. Use cleaning solution or isopropyl alcohol for stubborn stains. Ensure the screen is completely dry before proceeding.
Reminder: Take your time during this step to ensure a clean surface for the new screen protector.
Carefully align the new screen protector with the edges of the screen. Once aligned, use your fingers to gently press it onto the screen.
Caution: Avoid touching the adhesive side of the screen protector to prevent fingerprints or debris.
If any air bubbles are present, use a plastic pry tool or your fingers to smooth them toward the edges. Work from the center to ensure a bubble-free application.
Note: Small bubbles may disappear over time, but larger ones may need additional attention.
Inspect the screen for any remaining bubbles or dust particles. If necessary, use dust removal stickers to lift and remove particles. Ensure the screen protector is securely in place.
Reminder: Allow the device to rest undisturbed for a few hours to ensure optimal adhesion.
To replace the screen protector of TCL 30Z, follow these instructions in their order.
