Введение
The middle speaker can be taken apart and replaced if needed. A thin tool is required to take off the speaker guard as well as a Phillip's head screwdriver and a soldering iron to remove the speaker. Be careful when soldering the wires in the speaker.
Выберете то, что вам нужно
Push the nylon or metal spudger in the corner of the speaker guard.
Slowly lift the speaker up enough so that you can slide around the speaker guard.
Remove the speaker guard. You can now replace the speaker guard on your TDK Life on Record A33.
Remove all (4) 3mm screws in the middle speaker using a Phillip's head screwdriver.
Create an opening in the speaker by holding the device up and carefully grabbing the side of the speaker that pops out.
Remove the solder that connects the wires to the speaker. You should be able to now remove the speaker and replace it.
2 участников успешно повторили данное руководство.
3 Комментариев
Where can I buy the woofer?
