TI-84 Plus Silver Edition Backup Battery Replacement
Выберете то, что вам нужно
  1. TI-84 Plus Silver Edition Backup Battery Replacement, Main Battery: шаг 1, изображение 1 из 3 TI-84 Plus Silver Edition Backup Battery Replacement, Main Battery: шаг 1, изображение 2 из 3 TI-84 Plus Silver Edition Backup Battery Replacement, Main Battery: шаг 1, изображение 3 из 3
    • Push firmly down on the tab located on the back of the calculator near the center.
    • Pull the tab up, lifting it off of the calculator and exposing the batteries.
  2. TI-84 Plus Silver Edition Backup Battery Replacement: шаг 2, изображение 1 из 1
    • Removing the AAAs and the back up battery will clear the calculator's memory. Make sure you have backed up any important data prior to performing this step.
    • Push the positive (+) side of the batteries to remove them
    Removing these batteries and the back up battery will clear the calculators memory.
    Aaron Rueppel - Ответить
  3. TI-84 Plus Silver Edition Backup Battery Replacement, Backup Battery: шаг 3, изображение 1 из 1
    • Using the Phillips #00 Screwdriver, unscrew the 15 mm screw holding the backup battery cover, located above the main battery area.
  4. TI-84 Plus Silver Edition Backup Battery Replacement: шаг 4, изображение 1 из 1
    • Grab the plate and lift gently upward, to remove the backup battery cover.
  5. TI-84 Plus Silver Edition Backup Battery Replacement: шаг 5, изображение 1 из 2 TI-84 Plus Silver Edition Backup Battery Replacement: шаг 5, изображение 2 из 2
    • Wedge the small plastic opening tool under the backup battery in the gap to the left of the backup battery.
    • The backup battery is an SR44SW coin cell battery. You can also replace it with a size 357/303 or LR44 battery.
    • Push gently downward until the backup battery pops out.
Заключение
17 участников успешно повторили данное руководство.
Agustin
Участник с: 10/20/13
1 028 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 11-34, Amido Fall 2013 Участник Cal Poly, Team 11-34, Amido Fall 2013
CPSU-AMIDO-F13S11G34
4 членов
Автор 6 руководств
9 Комментариев
My son's TI 84 Plus C has a rechargeable battery with a little cord attached to it which is significantly different from the AAA's shown in this Guide!
annualgain - Ответить
Because it's a completely different calculator.
Ozan Munsuz -
Muy instructivo e ilustrativo que permite fácilmente la operación de cambio de bacteria.
Andres Guaty - Ответить
Do NOT replace the back up battery and the main batteries at the same time! If you do, you will lose all of the calculator’s memory.
Alexander Dombroski-21 - Ответить
Too late…….. I had about 13000 bytes of programs
Aaron Rueppel -
The TI-84 calculator backup button battery is a size 303 or SR44SW.
speedyfingers - Ответить
this didi’t work i have replaced both back up and main batteries
Michael Rubio - Ответить
This little button battery was insanely difficult to remove (and replace). It required me to deform my cheap plastic pry tool. Definitely poor design there from TI.
David P - Ответить
If the backup battery is dead and I remove it do I have to replace it before the calculator will turn on?
Taylor Sullivan - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 4
За последние 7 дней: 71
За последние 30 дней: 310
За всё время: 65,992
