Введение
This guide will walk you through the necessary steps for replacing the cooling fan in your Toshiba Satelite E45W-C4200X.
The cooling fan is a vital piece of hardware that prevents the computer from overheating and damaging the motherboard.
Before using this guide, make sure to review the troubleshooting page to ensure the fan will need to be replaced.
Make sure to power off your laptop completely and disconnect from any external power source prior to beginning the process.
Выберете то, что вам нужно
Using the phillips #1 screwdriver, remove the ten 1 mm screws from the back panel of the device.
Remove the four .5 mm screws that secure the heat sink using a Phillips #1 screwdriver.
Remove the two 1 mm screws that secure the cooling fan using a Phillips #1 screwdriver.
Disconnect the fan cord from the harness.
Remove the cooling fan and heat sink from the laptop.
Carefully peel off the tape holding the heat sink onto the cooling fan.
Remove the cooling fan from the heat sink.
Consider purchasing the entire H000085330 Toshiba Thermal Assembly E45DW-C4210. This includes the fan and heat transfer components assembled. As of January 2022, it is $14.00 on e-bay. This makes replacement much easier.
2 человек успешно провели ремонт по этому руководству.
