Введение
This guide will walk you through the necessary steps for replacing the power jack on your Toshiba Satelite E45W-C4200X.
The power jack has been a common problem with the Toshiba Satellite laptops and the replacement is quick and relatively inexpensive.
Before using this guide, make sure to review the troubleshooting page to ensure this replacement is necessary.
Make sure to power off your laptop completely and disconnect from any external power source prior to beginning the process.
Выберете то, что вам нужно
Remove the ten 1 mm screws that secure the back cover using a Phillip's #1 screwdriver.
Using a Phillips # 1 screwdriver, remove the three screws holding the bracket over the ports on the right side.
Remove the bracket.
Unplug the power cable harness from the motherboard.
Lift the power jack out of its slot in the top right corner.
Remove the cable.
Еще один человек закончил это руководство.
