TOSHIBA Satellite E45W-C4200X Screen Replacement
Выберете то, что вам нужно
  1. TOSHIBA Satellite E45W-C4200X Screen Replacement, Screen: шаг 1, изображение 1 из 2 TOSHIBA Satellite E45W-C4200X Screen Replacement, Screen: шаг 1, изображение 2 из 2
    • Using a plastic opening tool, remove the plastic bar underneath the screen.
    • Use caution when removing the plastic bar to prevent cracking.
  2. TOSHIBA Satellite E45W-C4200X Screen Replacement: шаг 2, изображение 1 из 1
    • Use the Phillips #1 screwdriver and remove the four screws at the bottom of the screen.
    • Be sure to store the screws in a safe place to prevent losing them.
  3. TOSHIBA Satellite E45W-C4200X Screen Replacement: шаг 3, изображение 1 из 3 TOSHIBA Satellite E45W-C4200X Screen Replacement: шаг 3, изображение 2 из 3 TOSHIBA Satellite E45W-C4200X Screen Replacement: шаг 3, изображение 3 из 3
    • Use the blue plastic opening tool to start separating the plastic cover from the screen.
    • Once started, use the Jimmy to run along the edges to complete the separation.
    • Be sure to go very slow to avoid cracking the glass further and possibly cutting yourself.
    • The camera is still connecting the protective cover to the laptop; we recommend setting it on top of the keyboard.
  4. TOSHIBA Satellite E45W-C4200X Screen Replacement: шаг 4, изображение 1 из 1
    • Remove the remaining screws that hold the screen in place using the Phillips #1 screwdriver.
    • Carefully lift out the screen and fold on its face.
    • The screen is still attached, do not pull away from the laptop.
  5. TOSHIBA Satellite E45W-C4200X Screen Replacement: шаг 5, изображение 1 из 3 TOSHIBA Satellite E45W-C4200X Screen Replacement: шаг 5, изображение 2 из 3 TOSHIBA Satellite E45W-C4200X Screen Replacement: шаг 5, изображение 3 из 3
    • Disconnect the screen from the small circuit board.
    • Gently disconnect with even pressure on both sides to prevent damage.
    • The old screen has now been completely removed.
Заключение
2 участников успешно повторили данное руководство.
masato tsuchida
Участник с: 09/23/19
348 Репутация
Автор 2 руководств
Команда
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 7
За последние 30 дней: 37
За всё время: 1,797
