Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Flip the computer over.
Remove the two 24.1mm Phillips screws near the front of the case.
Remove the five 33.0 mm Phillips screws towards the back of the case.
Carefully flip the computer right side up.
Lift off the top half of the case.
Near the motherboard, gently pull the keyboard ribbon cable until it becomes free.
Lift the keyboard out of the case.
Remove the nine 15.24 mm Phillips screws securing the motherboard in place.
When removing the spring door, make sure to keep the door closed.
Remove the 5 jumper cables from the motherboard.
Once the jumper cables lift the motherboard up gently; it should lift out easily.
Remove the two 40.6mm Philips screws securing the TRS-80 transformer.
Gently peel back the protective film on the top of the transformer.
Locate the two points the fuse is soldered into the circuit board.
Using a soldering iron and soldering wick, desolder and remove the fuse.
Place the new fuse into the location of the old one, and solder it in place.
3 участников успешно повторили данное руководство.
