Введение
The front and back cameras in this tablet are connected as one piece. Both cameras have to be replaced if either one is broken.
Выберете то, что вам нужно
Place the Tagital T7X on a sturdy surface.
Insert the plastic opening tool into the crack and pry open the tablet. Move the tool along the edge, while continuing to pry up the casing.
Use a spudger to hold the cameras in place.
Gently pull the black tape away using your finger.
Remove the ribbon cable from the motherboard.
Use a spudger to lift the two tabs, freeing the ribbon cable from the socket.
Еще один человек закончил это руководство.
