Введение
This guide will help you replace your taillight bulb on a Volkswagen Jetta (2011 - 2018). The most common problem on a vehicle is a burn-out taillight which can cause a safety hazard for other drivers on the road. Not only is this a safety hazard to other drivers but, you could also receive a fine from the Police.
By following this guide you will be able to replace your taillight bulb effortlessly without any special equipment/tools. This guide lists all the steps and includes detailed information and pictures of the process. It should take approximately 45 minutes to complete this repair but, it may take a little longer depending on your experience.
Выберете то, что вам нужно
Pinch the two release tabs towards each other and lift the bulb bracket out of the tail housing.
