Введение
In these instructions one will learn how to remove and replace the plastic screen for a kick drum.
In the demonstration below, the side being replaced is the one that has a microphone port, but these instructions are useful for either side of the kick drum. In this model, the bass drum is a Tama and has a diameter of 22 inches (the port hole cover is also 22 inches).
Выберете то, что вам нужно
Remove any attachments of the kick drum.
This includes symbols, toms, and kick pedal.
Repeat step 3 for all bolts that surround the rim.
Detach the bolts from the body of the drum; however, leave them attached and hanging loosely to the rim.
Rotate the rim to be sure that all bolts are free.
With both hands, remove the rim that still has the bolts attached and place aside for further use.
Remove the plastic microphone port from the drum.
This can be thrown away in the recycle bin.
Place the new plastic cover port on top of the drum so it sits perfectly on it.
Depending which microphone port is being placed, adjust the cover so that words will be properly read when the drum is placed upright.
Press down on the edges of the drum cover so it is snuggled into the drum.
Place the rim used in Step 5 back onto the drum.
Align the bolts so each bolt has an input that is attached to the center of the drum.
Finger tighten the bolts in a clockwise motion. Do this to all of the remaining bolts that are loose.
Evenly tighten the bolts with the same amount of pressure.
For an easier experience, tighten the bolts underneath the rim rather than above the rim. See the red box location in the pictures for clarification.
Use the drum key to tighten the bolts in a clockwise manner.
Turn the drum key one full turn (360 degrees) and move to the next bolt so that the same pressure is evenly applied to each key.
