Введение
Use this guide when the auxiliary port needs to be replaced.
Выберете то, что вам нужно
Wedge a spudger in between the front and back panel.
Apply leverage downwards to the spudger in order to remove the back panel.
Slide the battery out from under the brown wire-tape.
Be careful of the wires still connected to the other end of the battery. Do not pull or damage may occur.
Slowly pull the white plug from its receptor. Grasp its sides firmly with a pair of tweezers and gently wiggle from side to side.
Disconnect 2 brown wire-tape ends from each end of the motherboard. Gently pull straight out with tweezers.
Pull the motherboard and screen component diagonally up and left away from the auxiliary port entrance to remove.
Disconnect the 2 brown wire-tape ends from the left side of the battery slot on the motherboard using tweezers.
Disconnect the large brown wire-tape from the motherboard.
Peel the black tape back from the wire-tape using tweezers.
Lift the black, hinged, plastic lock with tweezers to release the wire-tape.
The screen and motherboard components can now be separated from each other.
Инструмент, используемый на этом этапе:Desoldering Pump$3.99
Remove the solder between the auxiliary port and the motherboard carefully with the desoldering pump.
