Введение
Use this guide when the directional pad needs to be replaced.
Выберете то, что вам нужно
Wedge a spudger in between the front and back panel.
Apply leverage downwards to the spudger in order to remove the back panel.
Slide the battery out from under the brown wire-tape.
Be careful of the wires still connected to the other end of the battery. Do not pull or damage may occur.
Slowly pull the white plug from its receptor. Grasp its sides firmly with a pair of tweezers and gently wiggle from side to side.
Unscrew the 2 Philips #00 screws on each end of the motherboard.
Disconnect 2 brown wire-tape ends from each end of the motherboard. Gently pull straight out with tweezers.
Grasp the upper left edge of the motherboard and slide diagonally up and left away from the auxiliary port entrance.
Unscrew the 2 silver Philips #00 screws from both sides of the directional pad component on the front casing.
Еще один человек закончил это руководство.
