Введение
Follow this guide to access the foot valve of a Tara pump. You can then replace or repair the valve, as needed.
Выберете то, что вам нужно
Lift up the handle and riser main until the joint between the two is at a comfortable height to work on.
Lift and remove the handle from the pump. Store the handle in a sanitary place to prevent contamination.
Loosen the jam nut from the base of the T-handle.
Unscrew the T-handle from the top of the riser main.
Remove the T-handle, making sure to hold the remaining end of the riser main to prevent dropping it down the well.
Use two wrenches to loosen the top section of riser main from the lower section.
Unscrew the top section of the riser main.
Make sure someone is holding the remaining section of the riser main.
Lay the first section of riser main in a sanitary place to prevent contamination.
Once the riser main and valves have been removed from the well, place a rag over the top to prevent accidentally dropping anything down the well.
When reassembling the pump, drop the foot valve down the well in the proper orientation, and follow the directions in reverse.
