Введение
The Taylor 342D-27 is a machine that is often used by businesses to make slush-type drinks. A damaged valve will not allow the machine to have a proper seal and the contents will leak. This repair guide can help you replace the o-ring and get the machine back in top shape. The guide can be used when either of the two o-rings located around the valve become loose, damaged, or broken.
Выберете то, что вам нужно
Make sure the switch for the machine is straight down in the off position and that all contents have been emptied.
Remove all 4 nuts from the front of the machine by turning them counter clockwise until they release.
Remove the valve pin handle on the top of the valve by lifting it upward and away from the valve.
Push the valve draw handle all the way to the right or until the flat lines on the top of the valve are perpendicular to the door face.
Remove the ice buster by wiggling it until it releases, then pulling it away from the valve.
Push the valve up using your thumb to remove. Once there is enough of the valve out of the top of the door to hold on to, pull it out.
Take off the broken o-ring using the o-ring removal tool. To remove, place the end of the removal tool under the o-ring and bring it out the other side.
Put a new, well lubed, o-ring back on the valve. The o-ring removal tool can be used in this step or just using pressure with your hands.
Еще один человек закончил это руководство.
