Введение
When your Taylor 3831S scale will not power on, it may be a simple fix and not that the Lithium battery is dead. Batteries need to be replaced periodically and this device will not work without one. This manual explains how to replace the CR2032 battery in the scale.
Выберете то, что вам нужно
Grab your scale and flip it over to get started.
Remove the small screw on the battery housing cover using the Phillips #00 screwdriver.
With the indented side facing the scale, secure the new battery in the battery housing.
Using the Phillips #00 screwdriver once again, replace the screw that secures the covering.
