Введение
The turntable is operated by a motor that spins a belt and the table. The belt may stretch or become misaligned over time, and may need replacement or adjustment. Note that it is first important to complete the Disassembly Guide.
Выберете то, что вам нужно
Separate the turntable from the top of the record player by lifting straight up.
Check the belt to see if it is off the motor or turntable. If the belt is damaged (tearing or lack of smoothness) replace the belt with a new one. If it is off track, realign accordingly.
Once the belt is ready to go, re-wrap the belt around the turntable wheel and, keeping it around the wheel, wrap it around the motor (indicated by the red circle).
Once the belt has been re-applied and the turntable re-attached, stand the record player back up.
To reassemble your device, follow these instructions in reverse order and complete the disassembly guide in reverse order.
2 участников успешно повторили данное руководство.
