Инструменты
Запчасти
Детали не указаны.
Remove back cover by applying pressure and sliding up towards the top of the phone.
Use Multimeter to test the voltage of the battery.
Put the black lead into ground slot of multimeter and the red lead into the V(ohm)mA slot.
Place the red and black leads to the two outside metal plate, each on opposite sides, on the battery as shown.
Check that the voltage displayed on the multimeter matches closely to the voltage defined on the battery. Normally 3.7 V.
Еще один человек закончил это руководство.
Один комментарий
Hello one the question was tablet not telephone and it's really vague how you guys explain these things you need to go to work on your site
