Teenage Engineering OP-1 Flex Cable Replacement
Выберете то, что вам нужно
  1. Teenage Engineering OP-1 Flex Cable Replacement, key removal: шаг 1, изображение 1 из 3 Teenage Engineering OP-1 Flex Cable Replacement, key removal: шаг 1, изображение 2 из 3 Teenage Engineering OP-1 Flex Cable Replacement, key removal: шаг 1, изображение 3 из 3
    • To get to the screws beneath the keyboard you need to take some keys off. You can use either an opening tool or an opening pick. The first picture shows how it should look like with all the necessary keys off (12 in total).
    • The four longer keys from the fingerboard are to be handled from the left side to get them off.
    • The eight smaller keys need to be levered from the bottom up.
  2. Teenage Engineering OP-1 Flex Cable Replacement, removing scissors mechanisms: шаг 2, изображение 1 из 2 Teenage Engineering OP-1 Flex Cable Replacement, removing scissors mechanisms: шаг 2, изображение 2 из 2
    • The scissor mechanism of the eight small keys are obstructing the underlying screws.
    • By using again an opening tool or opening pick these can be snapped off easily.
    • When reassembling be sure to place them in with the correct side facing upwards.
  3. Teenage Engineering OP-1 Flex Cable Replacement, unscrew keyboard: шаг 3, изображение 1 из 3 Teenage Engineering OP-1 Flex Cable Replacement, unscrew keyboard: шаг 3, изображение 2 из 3 Teenage Engineering OP-1 Flex Cable Replacement, unscrew keyboard: шаг 3, изображение 3 из 3
    • Loosen those 12 screws with a Phillips #00 screwdriver.
    • Then just pull off the four rotary knobs and the volume knob.
    • Now it is possible to slightly lift the keyboard and set it back.
  4. Teenage Engineering OP-1 Flex Cable Replacement, unplug and remove keyboard: шаг 4, изображение 1 из 1
    • Unlock the flex cables by pushing the two black nibs on both sides of each connector.
    • Now you can pull the flex cables out and remove the keyboard completely.
  5. Teenage Engineering OP-1 Flex Cable Replacement, remove display: шаг 5, изображение 1 из 3 Teenage Engineering OP-1 Flex Cable Replacement, remove display: шаг 5, изображение 2 из 3 Teenage Engineering OP-1 Flex Cable Replacement, remove display: шаг 5, изображение 3 из 3
    • Open the display cable connector by using a plastic opening tool to flip the latch upwards.
    • The display is held in place with a mild adhesive. A spudger helps you to get it free.
    • Now you can unplug the cable and take out the whole display.
  6. Teenage Engineering OP-1 Flex Cable Replacement, DSP Board: шаг 6, изображение 1 из 2 Teenage Engineering OP-1 Flex Cable Replacement, DSP Board: шаг 6, изображение 2 из 2
    • Disconnect the battery connector from the DSP board.
    • Unscrew the two Phillips #00 screws holding the board down.
  7. Teenage Engineering OP-1 Flex Cable Replacement: шаг 7, изображение 1 из 2 Teenage Engineering OP-1 Flex Cable Replacement: шаг 7, изображение 2 из 2
    • Now you can carefully lift the DSP board to access the flex cable connector underneath.
    • Disconnect the flex cable by using a spudger and remove the DSP board.
  8. Teenage Engineering OP-1 Flex Cable Replacement, Flex Cable: шаг 8, изображение 1 из 2 Teenage Engineering OP-1 Flex Cable Replacement, Flex Cable: шаг 8, изображение 2 из 2
    • Flip the OP-1 over to open the back panel giving you access to the connector board.
    • Disconnect the flex cable from the connector board.
  9. Teenage Engineering OP-1 Flex Cable Replacement: шаг 9, изображение 1 из 2 Teenage Engineering OP-1 Flex Cable Replacement: шаг 9, изображение 2 из 2
    • Returning to the front side you can unplug the flex cable from the UI board.
    • Now the flex cable is free and can be pulled out completely.
Заключение
3 человек успешно провели ремонт по этому руководству.
Tobias Isakeit
Участник с: 03/31/14
129 223 Репутация
Автор 189 руководств
Команда
Tobias Isakeit - Repairability Engineer Участник Tobias Isakeit - Repairability Engineer
Business
1 член
Автор 1 145 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 12
За последние 30 дней: 34
За всё время: 5,340
