Введение
No keyboard no sound. It's easy as that. But don't be afraid, replacing it is also very easy.
This guide shows you how to replace the keyboard of your OP-1.
Выберете то, что вам нужно
The four longer keys from the fingerboard are to be handled from the left side to get them off.
The eight smaller keys need to be levered from the bottom up.
The scissor mechanism of the eight small keys are obstructing the underlying screws.
By using again an opening tool or opening pick these can be snapped off easily.
Loosen those 12 screws with a Phillips #00 screwdriver.
Then just pull off the four rotary knobs and the volume knob.
Now it is possible to slightly lift the keyboard and set it back.
Your missing the ribbon decoupling step, unless you skipped it because it’s such a tight squeeze to get back in.
The concept of removing the square panels that the knobs sit on was skipped.
Unlock the flex cables by pushing the two black nibs on both sides of each connector.
Now you can pull the flex cables out and remove the keyboard completely.
I found bring the OP-1 higher up off my work surface made installing the ribbons much easier, oh and keep the keyboard assembly parallel to the OP-1 to ensure the ribbons seat evenly.
There ribbons are incredibly frustrating -- I cannot, for the life of me, lock them in place. Even after bending them, the direction of the bend itself creates tension that pulls them out of the zero insertion force connector. The black nibs do not seem to provide enough locking force. Frustratingly enough, this happens slowly over time, so usually 24 hours after I have fully reassembled the keyboard, it starts malfunctioning again. I would really appreciate some help here.
19 участников успешно повторили данное руководство.
18 Комментариев
Nice guide Tobias!
Worked like a charm. My OP-1 feels brand new.
Thanks iFixit X TeenageEngineering for providing these replacement parts!
Keep it up <3
Awesome guide! Thank you!!!
After reassembling everything I have one key ( the upper A) which retriggers the sound randomly if I press the key.
I hope that the reason is not that I put the flex cable back too loose … and i have to open it again. Anyone had this before?
This happened to me constantly, only by taking the key off I noticed the tiniest amount of moisture, a mere misting, nesting in the board. it had been re-triggering randomly… Not ideal whilst constantly gigging. Seems to be triggering normally now after drying it in front of a heater. The only thing I think could of caused this is a dry ice machine I played beside a few weeks ago.
Perfect. Thanks :)
Did this along with with replacing the connector board and it all seems as good as new. Recommended getting the Opening Tool, Spudger and for the connector board job the Jimmy. Well done TE for providing this to option for repairs.
keyboard replaced I have a new OP1 ;)
thx TE, hope you will bring connector board please !!!
Is this going to be available any time soon?
Solid guide. Solid fix. Nice to have my synth back in order :)
I have a a broken scissor mechanism on 1 single key of my OP-1, but it seems like my only option to replace that tiny broken part is to buy a whole new keyboard. Wondering if someone on this thread might confirm that (or offer and alternative). Thanks!
Take a look at these comments, maybe this will help.
Is this ever coming back? I spilled coffee on my OP-1 last year and some of the keys no longer work. I would really like to be able to fix this
Hi Michael, we’re constantly looking to get parts back into stock. Sometimes we are limited by our suppliers. But you can use the "notify me" function so you’ll know when it is available again.
After installing the new keyboard a sliver of the screen edge under the outer screen is visible. Do you think the replacement is manufactured incorrectly? Or is this an error with aligning the keyboard when reinserting it?
