Teenage Engineering OP-1 UI Board Replacement
Выберете то, что вам нужно
  1. Teenage Engineering OP-1 UI Board Replacement, key removal: шаг 1, изображение 1 из 3 Teenage Engineering OP-1 UI Board Replacement, key removal: шаг 1, изображение 2 из 3 Teenage Engineering OP-1 UI Board Replacement, key removal: шаг 1, изображение 3 из 3
    • To get to the screws beneath the keyboard you need to take some keys off. You can use either an opening tool or an opening pick. The first picture shows how it should look like with all the necessary keys off (12 in total).
    • The four longer keys from the fingerboard are to be handled from the left side to get them off.
    • The eight smaller keys need to be levered from the bottom up.
  2. Teenage Engineering OP-1 UI Board Replacement, removing scissors mechanisms: шаг 2, изображение 1 из 2 Teenage Engineering OP-1 UI Board Replacement, removing scissors mechanisms: шаг 2, изображение 2 из 2
    • The scissor mechanism of the eight small keys are obstructing the underlying screws.
    • By using again an opening tool or opening pick these can be snapped off easily.
    • When reassembling be sure to place them in with the correct side facing upwards.
  3. Teenage Engineering OP-1 UI Board Replacement, unscrew keyboard: шаг 3, изображение 1 из 3 Teenage Engineering OP-1 UI Board Replacement, unscrew keyboard: шаг 3, изображение 2 из 3 Teenage Engineering OP-1 UI Board Replacement, unscrew keyboard: шаг 3, изображение 3 из 3
    • Loosen those 12 screws with a Phillips #00 screwdriver.
    • Then just pull off the four rotary knobs and the volume knob.
    • Now it is possible to slightly lift the keyboard and set it back.
  4. Teenage Engineering OP-1 UI Board Replacement, Keyboard Connection: шаг 4, изображение 1 из 2 Teenage Engineering OP-1 UI Board Replacement, Keyboard Connection: шаг 4, изображение 2 из 2
    • Unlock the flex cables by pushing the two black nibs on both sides of each connector.
    • Now you can pull the flex cables out and remove the keyboard completely.
    • When installing the new keyboard, make sure to remove the protective film underneath the screen.
    • The OP-1 has a mode to test specific functions. You can enter it by holding the "COM" button while powering on, then choose the function test (2). You don't have to complete every test and can power off after the keyboard test.
  5. Teenage Engineering OP-1 UI Board Replacement, UI Board: шаг 5, изображение 1 из 3 Teenage Engineering OP-1 UI Board Replacement, UI Board: шаг 5, изображение 2 из 3 Teenage Engineering OP-1 UI Board Replacement, UI Board: шаг 5, изображение 3 из 3
    • The display is held in place with a mild adhesive. A spudger helps you to get it free.
    • Be careful since the flex cable is still connected.
    • Make sure the display won't be damaged when you flip it over to the front to access the UI board.
  6. Teenage Engineering OP-1 UI Board Replacement: шаг 6, изображение 1 из 2 Teenage Engineering OP-1 UI Board Replacement: шаг 6, изображение 2 из 2
    • Unplug the DSP flex cable from the UI board.
    • Unplug the speaker cable from the UI board.
  7. Teenage Engineering OP-1 UI Board Replacement: шаг 7, изображение 1 из 3 Teenage Engineering OP-1 UI Board Replacement: шаг 7, изображение 2 из 3 Teenage Engineering OP-1 UI Board Replacement: шаг 7, изображение 3 из 3
    • Use a Phillips #00 screwdriver to remove the five screws on the UI board.
    • To each screw there is a thick washer to fix the board. Don't loose them.
  8. Teenage Engineering OP-1 UI Board Replacement: шаг 8, изображение 1 из 3 Teenage Engineering OP-1 UI Board Replacement: шаг 8, изображение 2 из 3 Teenage Engineering OP-1 UI Board Replacement: шаг 8, изображение 3 из 3
    • Now the UI board is free to take out. You can grab it by the knobs and start lifting it on the right side half way out.
    • On the left side the speaker and its cable might be in the way to get it out straight. Just move it diagonally to the right to get it out completely.
    • Make sure the black plastic mat underneath the UI board stays inside.
    • After reassembling you want to check the board with the internal test function. You can enter it by holding the "COM" button while powering on, then choose the function test (0).
Заключение
10 человек успешно провели ремонт по этому руководству.
Tobias Isakeit
Участник с: 03/31/14
129 301 Репутация
Автор 189 руководств
Команда
Tobias Isakeit - Repairability Engineer Участник Tobias Isakeit - Repairability Engineer
Business
1 член
Автор 1 145 руководств
2 Комментарии к руководству
Can anyone recommend a good adhesive tape to fix the screen in place after doing the repair?
ossian moncreiffe - Ответить
No need to replace the adhesive tape as long as you leave it attached to the op1 or to the back of the display itself. So when you go to put everything back together, slot the display back into place, the adhesive tape that is there should stick very gently and when you go to put the keyboard with the display glass back, everything will be held in place.
Also, this guide skips over detaching the ribbon cables when you are removing the keyboard, the two connectors each have two (2 on each port) very small black colored locking mechanisms on the left and right of the cable's port, using a spudger you can push those locking mechanisms up about 2mm, and the ribbons should detach from the ui board seamlessly allowing you to gently pull them out. When putting it back together, insert the ribbon cable evenly to the new port, and push the locking mechanisms into place (reverse from what you did before).
sahdudeone - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 5
За последние 7 дней: 23
За последние 30 дней: 100
За всё время: 12,529
